Ok i got it. I set SELECT on Miles per gallon (MPG) and I push ADJUST for 2 seconds. Yep easy when you know it :thumbup:
Thanks everyone!
Yup the service manual I have covers 2011 but only shows the cluster and connector pin outs but doesn't describe function or changing settings.Buffalo said:Nothing in the service manual either.
I tried it again as you described, but the temp and MPG still reads C and Imp. I changed it a couple of times and the temp and MPG would not change back to F and MPG US.MrWick said:My owners manual says when you change from mph to km/h when pressing the select button for two seconds the temp will also change from F to C. I just went out and tried it on my 2012 the odometer needs to be displayed and when the odometer changes if you go back and look at the temp display it will be in C mode.
I tried it and pushing the adj button (the other button) did nothing. I am surprised that changing the speedo from MPH to KPH does not change the temp and MPG at the same time. The ODO changes with the speedo change.MJR said:If pressing the one button doesn't step through MPH/F to MPH/C to KPH/C and back over again does pressing the other button go back through it the other way?
