Has anybody installed a ccs-100 on the 650? mine is loosing about 9 mph on a hill,any info on that would be greatly appreciated. /
What is a ccs-100freddy cook said:Has anybody installed a ccs-100 on the 650? mine is loosing about 9 mph on a hill,any info on that would be greatly appreciated. /
Did you add a vacuum reservoir? Cause according to this site http://www.murphskits.com/catalog/produ ... cts_id=422 a vacuum reservoir isn't included in the base kit. You would probably need a reservoir and check valve.freddy cook said:Has anybody installed a ccs-100 on the 650? mine is loosing about 9 mph on a hill,any info on that would be greatly appreciated. /
A vacuum check valve should be between the vacuum source and the reservior, then the reservoir goes to the cruise control servo.freddy cook said:Mr.MJR,I ADDED A VACCUM RES.ON IT,WHERE WOULD A CHECK VALVE GO,THANKS.FREDDY.
http://shop.advanceautoparts.com/webapp ... 10302248-pfreddy cook said:Where is flaps.
I'm sorry, FLAPS = Favourite Local Auto Parts Store...MJR said:http://shop.advanceautoparts.com/webapp ... 10302248-pfreddy cook said:Where is flaps.
The vacuum pump likely has one already, though without knowing the specific model I cannot say for certain. In any event it will not hurt.freddy cook said:Mr. Cliff will I need it if I go with a pump and a vaccum control switch.Thank you very much.Freddy.
