Capacitors Failed! on my 22' Hannspree Monitor , Not sure if you all having this problems with your Monitor but Avoid the Repair Shops, And Be like Bob Vila ,Fix it your Self ,I purchased this Unit in Aug 2008, Just a month ago it started Taking 5-6 Minutes on Booting ON/ I opened it and found 4 1000uf 16v Capacitors 2 of them were Leaking from the Bottom, for more you can go on You tube, All 4 of them had Dome Tops on them.
Don't take it to the Shop there will just try to get more Money out of you and will Call China and order the entire Mother Board, Which is not needed, You just need a Soldering Iron + Solder + Nail Clippers to cut the ends.
Most Symptoms for Bad Capacitors: Black Screen,TV will not stay on,Taking 4-6 Minutes to turn ON/,Lines or bad Picture,ETC,ETC
I would like to here from any one who Did a Capacitor Repair on there LCD,LED ,Plasma TV or Computer Monitor.
Thanks,
Elliott,
Thanks,
Elliott,
