1 - 8 of 8 Posts
To fellow CA riders and/or fuel experts: In the past, I've seen a minor performance/mpg hit when using the winter blend of gasoline. This year it seems dramatic - with a 4 to 5 mpg hit on both my 400 & 650. Are any of you seeing similar performance drops? More curious than concerned. Thanks.
4 to 5 MPG is standard drop off here in the Corn belt. This year I have riddend in much colder weather so I have factored that into my estimate. No real change from last year, still bad MPG, but I have been riding in 20F and above, and there hasn't been much above to brag about lately.
I get most of my gas outside the "Designer" Gas Belt here in Georgia. :wink:
But when forced to buy the designer gas my MPG drops to 64-66 mpg range....urgh! :evil:
Cleaning of the idle adjust screw is needed more often when using the "winter blend" too. :roll:
Thankfully 8 miles away is plain old gas and 70 mpg! 8)
I love my 400 and it's modest consumption of gas. :D
Winter riding out here in the desert around Palm Springs mine drops down to around 60 mpg from my normal 65 mpg. I have been keeping tract from the day I bought it and that's been normal for the last 46K miles + :wink:
Thanks guys for the sanity check. Good to know it's just my mind and not my bikes
Steve & Mike - How do you guys average 60-70 MPG on your 400s? The only time I've ever exceeded 60 mpg was on a road trip using secondary highways where I averaged between 45 and 60 mph. In mixed everyday driving (city stop & go, some freeway at 65-70), I average from about 51-57 mpg. I know some riders do what I consider "outside the norm" techniques like shutting the engine at stops, or even coasting. What type of driving do you guys do? I'm assuming you both do a lot of open-road mileage?
Mine is mostly 2 lane open road 60-65 mph to work. Have about 5 miles of interstate of the 25 miles to work also. Just filled this morning right at 60.0 mpg. Dash showed 56.4, but we all know it runs 4-5 mpg low on the 400's :wink:
I have found on mine that 54-57mph indicated is the optimal speed for mileage on my older and smaller cc 400 than the 2007's and up. The older 400's typically get a touch better mph then the newer 400's anyways. I have also found that if I clean my idle adjust screw regularly that my mph doesn't taper off and stays optimal. That is one of the reasons I got a 400 and not the 650!
It also helps if the ride is downhill both ways. :lol:
Since last fall, I have noticed my mileage has fallen to around 45ish... Guess I will hold out final judgement till the summer blend comes out.
1 - 8 of 8 Posts
