1 - 2 of 2 Posts
Anyone changed the CKP (crankshaft position) sensor?
I'm reading 10 ohms across the sensor, spec is 180-280. Once I get the sensor out I will check again to be sure it's not the wire, but I'm betting it is the sensor.
The sensor is under the generator cover. Can I get this cover off with the engine still in the frame? It looks like it will clear now that I have almost all the plastics off.
Also looks like I need to drain the oil and radiator to remove the cover.
Anyone have any tips or advice?
Discussion Starter #2
I've contacted 3 dealers and 2 have told me that the sensor is part of the magneto assembly and not sold seperately. $230 :shock:
Hopefully its repairable...
1 - 2 of 2 Posts
