1 - 10 of 10 Posts
I have it slid all the way back, but it won't lock in. When I open the seat up it falls right out. Anything I can do to fix this?
There are notch's in the left side tube that the latch should lock into.
Yeah, they're there. Seems the latch to hold it is frozen up or something. Is there any kind of way to get at it without destroying the seat? I was able to work it back and forth but I still prefer the way the latch is on the 400. Much easier to slide in and out.
Open seat all way up, on left side (back look to front) there be a metal latch that serve to unlock butt rest from seat, it close on notch on butt rest rod, latch may be in open position or not in place, or missing.
If the 'stop-screws' on the end of the rods
have already been removed, go ahead &
slide the butt-stop all the way out.
Now you can remove the latch mechanism
from the seat pan, & see what repairs are
needed to make it work properly.
Ok. When I slide it all the way out I don't see a way to take the mechanism out from the seat pan
can you post a picture of the butt pad?
When you look at the underside of the seat, do you see 2 small screws in the post of the backrest bracket?
You can take it loose by removing the two large screws on the bottom of the pan. As far as I know there is no way to get it out without taking the cover and pad off the seat.
Discussion Starter #9
Ok. When I go to re do the seat and all I guess I'll have to tackle that as well. Thanks guys
Adding to the above.
Once you get the seat apart, look for a spring laying in the seat pan. A spring is used to provide tension, holding the slide lock in place.
That spring is attached to the seat pan and the other end is attached to the slide lock bar. That is the bar that engages the slots of the "butt rest" to maintain adjustment. Access to the tension spring is gained when the seat is removed from the seat pan, via the two large screws in the seat pan, as Buffalo stated above.
1 - 10 of 10 Posts
