Bob,
Have a look at this site ...
http://www.silverwing.co.uk/
Also has a link to Silverwing forum
Rgds Greg ...
Rgds Greg ...
Before I ordered my AN650, I had the opportunity to testride the Silverwing. I did not bother to do so, because in the Netherlands the Silverwing costs alsmost the same as the Burgman. The Burgman has more gadgets.Wambo said:Thanks Greg and blueburgerbob. Any input helps!! Both are great looking machines IMOO. I need any guidance from those out there that have made the decision, one over the other. Both look like a lot of fun, but the problem is to narrow it down when you don't have any to test ride. Also, if anyone can give me input into which company they've had the best luck dealing with is good also. I've owned Suzuki's in the past, and this may make me seem more likely to stay with that brand, but I'm open minded as to which may be the better choice, regardless. Thank you for your imput.
By the way, blueburgerbob, Bob is also my uncle!!
Bob
From what I hear the wobble can be reduced or eliminated by stiffening the rear suspension, keeping the front wheel firmly on the pavement.foxy said:...The Honda has a stiff ride and had a noticeable wobble at higher speeds...
Excellent read. This will help me greatly in my decision. Thanks.lycheed said:I'm actually an AN650 owning Honda man - I own four of them at the moment and was hell bent on making it five with a SilverWing. What stopped me doing that?
1. I already own a NSS250 Forza/Jazz/Reflex ABS - I don't want to use the Burgman around town. A 250 scooter wil piss on the AN650 round town. The SW has a similar ability.
2. I wanted to use the machine for touring in tandem - the stronghold of the AN650
3. Character is important to me in a motorcycle (my other Hondas are the brutal x11, and the RVF400 + 750 endurance racers). Whether others agree with my taste means nothing to me. 270kgs all in, and a auto clutch that takes some getting used to when filtering - that's what I call character...
4. I like the idea of having selectable transmission modes - PowerMode is especially usefull for controlling the machine on the downhill run of a mountain pass.
5. Carrying camping gear without using a top box is important to me, so both the shape and volume of the underseat trunk is crucial.
For these reasons, the AN650 won hands down - despite being 2000 USD more expensive, and despite is not having ABS or CBS which I actually suits a touring bike very well.
If you want the most stylish and comfortable way to get around town then it must be the SilverWing ABS. If you are planing to go touring, it's the AN650. They are built to fulfill different goals. I wouldn't even consider the similarly priced low tech European singles when the SW and AN650 are using smoother twins.
Suzuki also build the stylish and easy-to-ride-in-traffic AN400 - this is really it's direct competitor for the SW, Atlantic and X9, not the AN650.
The AN650 is in a class of one - much like the GoldWing, and the VMax was until the X4 came along. Wambo, buy the one that suits your planned usage
Yeah....enthusiastic Silverwing owners say you can sort out its handling by buying new rear shock absorbers (eg Fournales air shocks), and new front fork inserts (eg HyperPro)....but why should an owner have to fork (sorry) out several hundred quid/USD just to get it handling properly???Bazza said:Check out the front forks on the SW...they're bicycle forks..ONE triple clamp and a head stem.
Burger (and TMax) have full length forks, TWO triple clamps, just like a motor cycle. Incidently the Gilera 800 also has bicycle forks.
Bazza
