1 - 8 of 8 Posts
Hi all, I took off the main oil drain plug and the plug next to it. I changed motor oil and filter . I cannot find the fill hole for the main gallery plug. Any help would be appreciated. Thanks
You dont mess with the gallery plug you drain the oil refill the engine via the
plastic filler plug up to the full line in the oil window with the scooter level
then start the engine the oil pump pumps oil round the engine run it for a few min
stop it let it stand about 3 min and recheck the level.
Never seen a engine were you take the gallery plug out to change the oil,
unless I am misunderstanding your post.
I made a mistake and I took that plug out first then I knew I screwed it up. Thanks
Gallery plug
Are you saying that adding oil in the oil fill will fill the other gallery? 5 ounces came out and it was very clean.
qman in your profile you don't say what part of Florida you live. If you are anywhere near St. Pete. I would be happy to come take a look at your scooter and help you. There are a lot of Floridians on this forum and if you were a little more specific what part of the state you lived you may find that someone close would offer to help. ;)
Ok just to put your mind at rest, put all the pugs back in
and the new oil then start the engine for a few secs stop it
and remove the gallery plug you should get a small amount of oil out.
oil gallery
Hi, model 28 I live in West tampa. Thanks
Discussion Starter #8
oil gallery
Thankyou ralph, I really appreciate the information.
1 - 8 of 8 Posts
