I have a 2003 Burgman 650 with 58k miles on it. There's gear oil splatter around the rear wheel and tire. I removed the wheel and the gear box cover, the gears look good, there's gear oil on the wheel side.
I cleaned it up, re greased the wheel, and rode it for a week, 45 miles, then 30, 40, and after another 40 miles, the splatter returned. I thought I checked the wheel after every ride and it was clean, I think the splatter happened while it was parked (but I'm not sure 100 percent)
Does the final drive gear box have a pressure relief hole or valve?
I put 75w90 gear oil. Would a different weight oil alleviate the problem?
The right side seal is $40 to $50. I'm not positive that's the problem. I'll do the cleanup and test ride again one more time, with fresh clean gear oil. If it does the same thing, I'll remove the seal and see how it looks.
Any suggestions and guidance would be appreciated!
