1 - 3 of 3 Posts
Does anyone know where the grease points are for the Burgman 400? I know the side stand and center stand must be greased, but does anyone know if we should apply grease on the CVT clutch shaft and the front and rear wheel axle shafts as well?
I just wanted to know if what the parts are to grease it.
Do you have a copy of the shop manual? The front wheel info is found on page 7-20. It appears that there is no grease on the rear wheel hub or the clutch. I personally would add a tiny bit to make sure the parts slide on the splines easy{mainly for removal next time}.
Thanks. Exactly what I also thought. Although it doesent call for grease, it's still wise to put a little on
1 - 3 of 3 Posts
