1 - 3 of 3 Posts
mine only has 19,500 miles on it and the front has been wobbling for a long time now, looking forward to fixing it with a simple bearing replacement. Cheers!
Hi All - The bearing replacement was a pretty simple straightforward replacement job. Unfortunately, that was not the cause of my wobbles. The bearing were actually in really good shape, I'll measure and take pictures and post them. Discovered that the wobbling must be coming from the notched steering bearings.
Here are the pics
So, Ridesafe supplied the sizes for the front wheelbearings and they are
6202-2RS.
These run between $11 for steel balls all the way to $300 for hybrid Ceramic balls. They come with rubber seals on both sides that the rubber is in contact with the hub and race so just a LITTLE bit more drag but for around $15+ you can get non-contact and lose a SMALL amount of drag, SMALL is the key word.
You may find them in kit form that has 2 bearings and the outter seals. Sources like 'All-Balls' or Ebay and even major Bearing supply houses Like Applied.com
Reactions: Gio
1 - 3 of 3 Posts
