1 - 4 of 4 Posts
When I was reassembling my clutch cover I noticed while regreasing the clutch cover bearing one of the seals was missing a bit of material around the inner race. I'm thinking it might sling some of the grease out of there. Looked up the bearing on Service Honda and Suzuki wants $43.15 for it.
There seem to be many cheaper alternatives if you want to replace it.
6007-2RS C3 EMQ Premium Rubber Seal Ball Bearing ABEC-3 35x62x14 6007 2RS 6007RS | eBay
Even if this one does not last as long as the oem you can get 6 for the price of the Suzuki.
I'm going to put back the original with the bad seal facing away from the clutch drum and replace it next time.
If anyone has found an alternative for the two bearings in the Clutch fixed driven face this would be a good place to post it to keep them all in one place.
Reactions: John Holbrook
2014 Burgman 400
This bearing and gearbox shaft bearing are the main load carriers in the rear pulley, good quality here is a must IMO.
1 - 4 of 4 Posts
