1 - 4 of 4 Posts
I recently dropped my 2008 Burgman 650 (I slid in wet grass in my yard while attempting to park). The only damage I saw was a crack at the end of my exhaust pipe (just the plastic end). When I rode it again, I was bouncing A LOT! The entire ride! The tire pressure is good and the shocks are intact. Can anyone give me ideas to what is wrong?
When you say the shocks are intact, did you also check the collar that adjusts the pre-load? You might have moved it to a different position without you knowing it. Make sure the two sides are equal.
Maybe your forks are out of alignment - will cause odd handling and not obvious.
1 - 4 of 4 Posts
