1 - 7 of 7 Posts
2004 Burgman 400..Okay Back brakes i can pull the right lever in and the brake lights work on both sides. i can press the left brake lever and i get no brake lights dont understand why one side works the other side does not it has to be something simple..im sure someone else has prolly had this issue im new to the board but sure could use some help Thank You!!! :)
The problem is the micro switch on the left brake handle. Simple job to replace it. It is located under the lever right at the pivot point. You remove one nut and unplug the wire to take it off.
Sometimes a good cleaning will fix too.
Discussion Starter · #7 ·
yup got some eletrical contact spray and gave it a good spray installed it back on .how about that it's working ,but i sure do appreciate the help,help is always a good thing :) :thumbup:
1 - 7 of 7 Posts
