1 - 5 of 5 Posts
Does anyone know if the BrakeAway Cruise Control and Kuryakyn Grips are compatible with each other on a 2013 Burgman 650?
Works on my 2009.
from the specs it says it may not work with after market grips as they are designed for the diameter of the stock ones, however if you tinker with BreakAway you may be able to install it, it comes with a plastic "o-ring" that you can play with.
1 - 5 of 5 Posts
