Brake Rotars
It seems that my hot rear rotor may have had several causes. First, the emergenct brake was correctly adjusted, and speed on the centerstand was 7-8 mph. I think heat from the several sources suggested was a factor, because in the 15 degree cooler weather the last two rides, there was no excessive heat. Also, the original problem of the faulty cocked caliper piston may have caused uneven wear on the pad which has now evened out- but there is no evidence of excessive wear. Thanks to you all for your input. BTW, since my original warrenty expires next week, I bought the first extended warrenty in my life, a SEP for the next 36 months through the local dealer for $349. Sorry for the long post.
