When I start my bike my brake lights are on as if the brakes has been applied. When I press the left brake I hear the clicking sound, but when I press the right brake it feels stiff. It doesn't click like the left brake lever. Could it be a problem with the right brakes or brake lever?
Question: After you start the bike, do the brake lights turn off after depressing and then releasing the brake lever(s) again, or do they remain on?
There is a good chance it's the brake switch, take it off and spray some contact cleaner in the switch then spray some contact grease, it should do the trick.
They stay on.
I would unplug the micro switches on the brake lever one at a time and see if the lights go off. If they do then you know you have a bad switch.
Had the opposite problem with my K05. The switches wouldn't turn on the brake light i.e.. and the scoot would not start. I purchase a spray can of contact cleaner from Radio Shack, problem solved. Funny that both switches both front and rear quit working within days of each other.
