Never mind that they said it would just be a dusting of snow (it's still snowing and accumulating).
When I rode in to work this morning, the temp was around 20 degrees.
I noticed that my brakes felt like the hydrolic fluid was having a hard time moving - the handles, when applied, felt like the brakes were sticky - the best I can describe it.
Does anyone know if brake fluid is severly affected by cold? I've ridden in the cold before but never experienced this problem.
I'm a bit concerned. It's due for a fluid change this summer anyway, but the fluid does not show any indication of burning or water (it's still very clear).
Cold weather wouldn't effect brake fluid unless there was quite a bit of water in it which yours doesn't have. My guess it's more in the slide part of the caliper that is hanging.
OK - so how/what would one lubricate this with (a warmer weather project)?
Check slider pins on caliper makes sure caliper isent dragging...Check hand lever for binding.
Thanks - if the problem clears up with the warmer weather, I can add it to my spring scoot "to do" list. I've got a project that I want to try.
