Status
Not open for further replies.
1 - 11 of 11 Posts
So I had to replace the pads the dealer put in when they did my tires- I mentioned they forgot the shims and spacers and of course the new brakes squealed at every dang stop. I wound up putting back in the OEM I still had since they had good wear. I also felt they didn't properly push back in the pucks as the brakes felt funny- especially the rear.
I watched Mitch's videos 3 times in certain areas so I did this correctly. Now after riding a bit (felt great by the way- better than ever!) - however now I hear my rear pads dragging - even when just manually wheeling the unpowered bike around. I even put the bike up on the center stand and started it up and gave it gas so I could hear and observe the problem without a helmet and being on the bike- sure enough - this needs adjustment- question is - what can I do? Sorry- I've no service manual. (still looking)
Thanks for any tips!
this could be one of those things with brake pads being like a new girl friend she''s gonna make a lot of noise and create a little drag until you get her rubbed in all the right places enough times to smooth her down a little , if it's just noise and not performance , loosen your exhaust bolts, and enjoy the rubbin, if you have performance problems you will know it on the center stand according to the video
Sounds like your parking brake is the issue - disconnect the mechanism (secure it safely) and see if the issue persists.
I put the old pads back again for the time being so I don't think that's the rubbing problem the parking brake is an interesting thought I'll look into it.
Please tell us more John.
John - if I may point out you did not add any clarity to this thread. I highlighted the parking brake may have needed adjustment (eliminating)and the o/p understood. Your brief post appeared contradictory.
OK John that is clearly understood - have a read of the PM I sent you.
1 - 11 of 11 Posts
Status
