1 - 2 of 2 Posts
Does the new Bestem 929 top case mount the way the old 929s did with a 3 point connection similar to the GIVI monokey? If I remember correctly, my old 929 mounted on it plate with two pegs and a latching block. The only difference I could see between the Bestem and the GIVI Monokey mounting points was the latching block was turned around 180 degrees from the GIVI Monokey latching block.
Is this still the case with the Bestem 929s? The mounting plates Bestem sells does not show the three point mounting system???
Don't know about the 929 box, but my model 2012 came with a plate that mounted on to the universal mounting plate they sell separately. The plate that came with the box had the three point mounting system, and that bolted on to the universal one. The universal one then bolted on to the bike itself.
Basically the universal plate is a substitute for all the hardware you needed to provide to mount the plate that comes with the box. If that makes sense.
1 - 2 of 2 Posts
