1 - 9 of 9 Posts
I took a long trip Sunday, about 240 miles round trip. On the way out I was about 85% highway at 70-80mph and I averaged 59mpg. On the way back I went on the interstate at 55-65 and I got close to 75 mpg....so what's that sweet spot speed?
There are so many factors to be considered that your question is not an easy one to answer. Wind - road surface - terrain (hills)... Is your speed constant or not.?? Is there traffic in front of you? Are you unknowingly drafting.????? Even the ambient temperature makes a difference.......
I find 50/55 and that it seems to do better if you accelerate smartly up to
speed rather than slowly, a tend to accelerate up to just over the speed I
cruise at then let it settle down to that speed, in theory the best cruising
revs for MPG are max torque revs 5750?
http://www.fuelly.com/driver/blackfive/burgman-400
· Premium Member
For the most part I try to keep my 06 400 at or below 65 mph (actual as measured on the GPS). It runs just fine above that speed but uses much more gas. I seem to get my best mileage when running between 55 and 60.
As a general statement I get the best MPG if I keep the rpm below 6000 (65 MPH actual GPS). On my 886 mile round trip last week I averaged 62 MPG, but on one leg with a nice tail wind and gentle cruising on country roads I attained 68 MPG calculated at the pump. I was also carrying about 50 lbs of camping gear, and my sleeping bag on the pillion.
I am happy with anything over 60 MPG. That is what I base my range to the next fill up on.
You'll have to figure THAT out for your self and YOUR ride.
It's intuitively obvious to even the most casual observer that higher speeds consume more fuel; so you apparently fount it! :cheers:
It's more like what RPM for the best mileage!
I have found that between 5700 - 6000 rpm is where I average my 70mpg.
Of course that is right at the return speeds you mentioned. :thumbup:
As an experiment - last Sunday, I filled up my Ingrid Burgman........and rode about 60 miles - being careful not to crank it on from a standing start and keeping my speed to 50-55 MPH with engine RPMs about 5,000 to 5,500 - a was surprised to get an indicated 66 MPG... So.I think that there is a "sweet spot" for getting the best MPG.
1 - 9 of 9 Posts
