1 - 4 of 4 Posts
I have a Kriss headlight modulator on the way. Where/How do you recommend locating the light sensor?
Discussion Starter #2
I forgot to mention. To be mounted on 400; if that makes a difference.
What I did with mine, on my 650 is just run the wire up and out by where my left mirror folds out. I did not want to drill a hole. So the sensor sort of pokes out from under my mirror. Easy install. works fine and allows the sensor to see the road surface fine.
Be creative.
^Did the same, except mine's on the right side since I have a RAM mount on the left brake reservoir. I am positive you could hide it a lot better though.
1 - 4 of 4 Posts
