1 - 4 of 4 Posts
I currently have 600W Shark Audio system set up on my Scooter (2012 AN650 Exec). I have the speakers mounted on brake calipers. One of the speakers started to come on and off. So I am due for replacement speakers. I was wondering in your experience which handle bar speakers sound the best?
Thanks in advance
Matt Kas
Make sure that you don't have a loose connection
in the speaker wires....or maybe a failing solder-joint.
A pinched wire can also be intermittent.
Thanks.
I soldered a totally new line to this speaker. Still had the intermittent issue.
I swapped the audio jacks. The other speaker did not have any issues.
How I confirmed for sure was when I press with my finger in the center of the failing speaker: When I push and keeping pushing with my finger the failing speaker always turns on and the issue goes away :) Sounds like some intermittent issue inside the speaker which is one of the common failure modes for speakers.
It appears that you have a damaged voice-coil
in the speaker......
yep....replacement is the only solution.
Good luck.
1 - 4 of 4 Posts
