As a rule I have an emergency tire repair canister in both my car and the Burgman. I do not ride the Burgman without one. I also ride a road bike (bicycle) and you may know, cyclists always have a pump and a patch kit with them. Some ride with a Co2 cartridges. These cartridges (25g) can hold 850 Psi. They are used in soda stream and paintball guns. Unfortunately that 850 Psi is just pressure and not much air. On the road bike it will inflate a skinny tire to around 7 bar, which is enough (race road bikes can handle that type of pressure). However it will not inflate your car or motorcycle tire even enough to continue your trip. But about four 25g Co2 cartridges, I believe, will inflate your Burgman to around 40 Psi which is where you want it, more or less.
So I tried this and it works. I let my rear down to 30 Psi and then I inflated it with one 25g cartridge and pressure went up to 42 Psi, which means that 4 cartridges will be enough to go from flat to about 40 Psi. The canisters of tire goo will not inflate to 40 Psi and you always have to ride slowly to the nearest garage and inflate further. Well no more. Just fix the flat with the tire goo and inflate further with a few Co2 cartridges.
These two pictures show the applicator and a 25g cartridge. You can buy both from any bicycle shop. The copper side of the applicator goes on the valve and the cartridge into the other end. There is a sharp tip that will pierce through the protector on the cartridge. I had to use a short tube valve and cut the bottom tip of as it would be too long to go into the copper side. The reason why I inserted the valve is because there is nothing inside the applicator that will press against the tip in your Burgman valve to let air in, as these applicators are designed for Presta bicycle valves whilst your Burgman and car has a Shrader type valve . In the picture you can see the inserted valve. So then I proceeded to screw the copper side onto the bike valve with the turn knob tightly in closed position. I then screwed the cartridge into the other side and slowly, as I didn't know what to expect, and within about two seconds the cartridge emptied itself, and like I said, pushed the pressure from 30 to just over 40 Psi.
I am sure four of these 25g cartridges will go from completely flat to 40 Psi, because the Burgman's air capacity is not that big (based on one going from 30 to 40, so I think 1 cartridge for 0 to 10, another for 10 to 20, 20 to 30 and the fourth from 30 to 40 unless my understanding of air volume and pressure is wrong in that there could be a distinct difference between . 30 and 40 Psi and say 0 to 20 Psi). Your car tire might need 10 cartridges. I have not tried that but I think it will go that way. It's fuss less and I didn't even get my hands dirty.
