On my way home from work (approx. 50 miles) the other day, at two miles from home, my bike started smelling like rotten eggs ( battery acid / sulfur). I threw a volt meter on the battery while it was running to check the voltage but it seemed normal between 13.8 to 14.2 volts, even when I revved the engine up. I removed the battery using a rag, as it was so hot I could not touch it. The outside of the battery case was melting inward.
Also both headlight blew out some time the previous week. coincidental?
Can anyone tel me what to look for first. Is it possible just the battery went bad? It is a one or two year old Walmart battery that was starting to go dead and would not hold a charge more than a few days. I kept it on a trickle charger when it was not in use.
Or is it something more serious? if so what?
I was planning on buying a new battery and checking the voltage again.
Any help would be appreciated.
Thanks, Greg
Thanks, Greg
