1 - 9 of 9 Posts
big mistake today, i reverse the battery s cable. :p
anyone know what can happen? i turn the key 3 times before to return the cable in good position.
now nothing is working
First place to check will be main fuses around battery. I know on cars the ECM doesn't fair good when that happens. Hope your error just took out some fuses.
Remonte ton siège, coté gauche avant sous le siège deux fusibles de 40 ampères chacune, une pour la CVT et la deuxième pour tout le courrant de la moto, vérifie les deux si une ou les deux ont brisé pas de dommage au panneau électronique du ECM
Under seat, left front lower position, 2 x 40 amp fuse one for CVT other for control all electricity for bike, verify that these not broken or damaged. if these blown probably this protected ECM when crossed wire.
You may have blown out the rectifer in the charging system too. Like Mike said, the biggest worry is that the ECM has been damaged.
Les fusibles ont fais leurs boulots.
Fuses work good and protect system.
Quick, go out and buy yourself a lottery ticket. You got that lucky with this.
Namaste'
Doug in Kentucky
1 - 9 of 9 Posts
