1 - 7 of 7 Posts
new thread in response to a previous battery post,
My 15, (purchased new ) has the original battery and has not yet shown a sign of weakness, I am aware they die over time and am expecting mine to go soon, usually I have found 5 years to be about max, I know it differs a lot on climate, riding time, days ridden etc etc but maybe there's some hidden knowledge out there that will help others concerning battery life.
Mostly all I can say is keep a trickle charger on it any time the temp gets below 50 F .
some aircraft I used to work on had a blanket heater on the batteries that kept them warm at altitude cause cold really weakened them in a short (1-2 hours) time and they weren't cheap or little batteries. (2 at 90 lbs each, changed every 90 days needed or not, learned some of my best cusswords haulin them things around)
When I lived in Chicago if you had a weak battery it would not turn the car over on very cold nights. The battery would work the rest of the year accept for the 2-3 days of below zero weather. I actually took my battery from my BMW to O'Reilly yesterday to perform a load test since I have no idea how old it is. They said they do not have the equipment to do a load test on a motorcycle battery. What they can do is put it on a trickle charge and see if it takes a charge. I guess I'll check it with a volt meter. Also my 2016 Burgman battery is coming up on 5 years. Reading articles on line they say 3-5 years.
You can do a quasi-load test on the bike just by turning on the lights and watching the battery voltage over time. Can't tell you what voltage you should see, but I would think it should hold above 11.5 for several minutes. Then when you start it up the voltage should recover fairly quickly.
Reactions: Dave_J
Discussion Starter · #4 ·
I'm not in favor of a voltage test unless it is done under a load, a battery will read good for voltage and not have enough amperage to jump start a nervous cat, a weak battery will drop voltage under a large enough ampreage drain like described above
2013 Suzuki Burgman 650 ABS
Replaced my battery just today while I was checking the CVT filter on my 2013 Burgman 650 ABS. I suspected the battery that was in there was original from 2013 and I suspect I am reading the date code correctly to confirm that. Do you think just over 8 years is long enough for a stock AGM type battery? 😁
There is a code stamped into the plastic on top the old battery of 130303 (year-month-day?). There is another code ink stamped into the bottom of the old battery of 130304-1. It was still working just fine but I am planning a long-ish trip from central Iowa to North central TN in another week so didn't want to be at some remote camp ground with a dead battery. I do always carry mc jumper cables just in case but still...
The battery I put in came compliments of Amazon:
https://www.amazon.com/dp/B07P6Z7TV3?psc=1&ref=ppx_yo2_dt_b_product_details
I know the Ah is .2 less than OEM (12Ah vs 12.2Ah) but I think this one will work fine for me. I usually plug into my battery maintainer if I don't ride for a few weeks but that is rare. I usually ride every month of the year even when temps go well below freezing for 3 months in a row.
I was shocked to find out that Texas Heat was as bad as Ohio Cold on batteries and windshield wipers. You can’t escape it.
1 - 7 of 7 Posts
