1 - 8 of 8 Posts
On '07+ 400's there are air vents directly under the turn signals on both sides of the bike. Does anyone know what these vents are for?
Thanks. Bill...
On my 2011, if you look close, there is black plastic panel inside the openings, kinda like a grill made of long ribs.. Some of the ribs on the panel are dummy's and some of them have openings between them. So I wonder if they were just dummy vents, why would there be some opening in it... So many things to wonder about.
Bill...
The Left Side sitting on bike is A Open Vent , Is for Cooling the Regulator/rectifier
Thanks Elliott..
Bill
I thought they were for the temperature gage.
temperature gage, is on the Other Side!! Which is the Dummy Side!!
Did a little Water Proofing on the side of the Regulator/rectifier where i suspect water would flow down into Regulator/rectifier,the connector is water proof, sealed just as long as any water Jets are not used in that area. it seems to be ok!!
1 - 8 of 8 Posts
