After reading all the good comments about the 2013 650, I traded my GW for one today.
Here are things I found out today about the 2013 650
Windshield
- has 6 well nuts instead of 4
- upper body and head is pretty good at 60 mph (speedo) for a stock WS
- I am going to take the ’11 stock WS and compare it to the ’13 stock WS. I am also going to look at the well nut holes to see if they line up. I will take pics
Speedo is off 7-8%. Makes it a very harder to calculate your speed. I think I will just use speedo +5 mph
Engine seems to run a little low rpms at hwy speeds. I need to check against my 2011 sometime
-3,500 at 60 mph (speedo)
-4,100 at 70 mph (speedo)
Power mode - 1,500 rpms higher than D, instead of the 1,000 rpms higher
Engine braking - has been reduced, no more neck snapping deceleration. Seems more like a regular bike
It is easy to push around and “duck walk” around, I guess the clutch drag reduction worked
Gas tank filler - there is now an insert in the filler that has a hole just the size of the pump nozzle and the cross bar is below the insert
Mirrors - they now rotate in the housing, if you do rotate them it looks odd to have the mirrors not aliening with the housing, but you do get a little wider range of view
Buttrest - larger and has only one stop screw that is easier to remove. In the seat cover there are larger/longer rubber seals around where the rods slip into the seat. I guess to seal against the buttrest to stop water???
Seat - good with the buttrest removed, but I liked the older one also
Sits higher?? - I sat on my ’11 also, it does seem sit a bit higher
Legroom - about the same with the buttrest removed
Front floor boards - “may” have a bit more angle to them
Top box - you will need a cover plate to fill the void between the passenger hand rails and the trunk mount. It still uses a 3 bolt mount pattern. I may take the trunk mount off my ’11 and try it on the ’13. If I do I will take some pic
Handling – it seems to track straighter with less input and corner better. It feels more planted. This maybe because it is a new bike, odd air pressures the dealer put in the tires, or a half dozen other reasons, but was today’s impression
Handlebars - look and feel a different, but I use up and backs on my bikes so it is hard to tell for sure
Handlebar ends - are more secured
That is all I can remember from today. I will report things as I find them. I looks like rain here a few days so it maybe a while before I can do some riding comparisons.
I like the new 650
Windshield
I like the new 650
