I recently acquired a 2005 AN400 with 5000 miles on it. Ran fine about a year ago but the previous owner let it set. Pumped out the fuel and added fresh. It will start easily and idle for 20 seconds or so then miss once, run a few more seconds and die. After10 seconds or so it will start again and repeat the process. I can rev the engine for about 20 to 30 seconds but then it again dies. I checked spark and it's OK. To me, it seems like a fuel issue. What I have done so far -
Checked the injector - Ohms reading OK at 11.4 Applied 9v to injector - it appears to pump fine as I can feel air movement out the nozzle and hear/feel it run
PULLED THE TANK! Yes, I went to that extreme. Inside looks pristine. Pulled the pump/filter/gauge assembly. There is zero debris on the plastic screen - I mean clean. Applied 12v to fuel pump and it appears to run fine. I did not disassemble the unit to check the filter because the screen was so clean. Was concerned about replacing the plastic zip ties. Not sure if the hardware store variety would withstand constant submersion in gasoline.
SO now I am at a loss. Tore it completely down (not 100% sure I can get it all back again) and still have no idea what the problem is. ANY suggestions would be greatly appreciated.
