1 - 5 of 5 Posts
There are replacement key kits on eBay (with magnet kit) but they list it as compatable with 04-09 AN400's. Are the 03 AN400 keys the same style?
I'd hate to waste the $$ and 2 weeks for international shipping...
Like wise he does not say the 650 key is same size as 400 but they are. He does not care to keep his stuff listed very well. Ask him your question.
The key blanks for all Burgmans are the same. The early and later 400's are identical in every way, the 650 has a much larger plastic end on it but the shank is identical to the 400's. They all fit in each other's ignition switch, they all can lock each other's shutter. The early 400 has a bigger face plate on the ignition switch so I don't think you could use one of those switches in the later 400. The switches on the newer 400 and the 650 appear to be the same size so may be interchangeable.
The key itself between all three should be fine though. Note I'm comparing '06 and '07 models. Don't know if there was a difference on the '03 model.
1 - 5 of 5 Posts
