1 - 13 of 13 Posts
Does anyone know of a plug n play bulb that will work in a 2013 Burgman 650 that is the bright white/blue color instead of the factory yellowish color?
thanks!
-Eric
I run Silverstar Ultra 9003's in my Burgmans. The H4 and 9003 are the same fitment. The Ultra's have a bit wider beam to the right and a lot longer reach too.
Reactions: Just Jim
The bulb is an H4....or a 9003
at any automotive parts supply..
Auto Zone...O'Reillys...Advanced Auto..
Pep Boys...NAPA (more expensive here)
9003 Halogen should cost about $11.00 each.
They have 2 small locator-pins in the metal
base...just bend then flat with a pliers.
Silly question I'm sure, but do you replace both the high and low beams with the same 9003 bulbs?
Thanks.
Yep...they are dual-filament bulbs.
Stock bulbs are 35w on Low beam
& also on High beam.
9003 halogen bulbs are 55w on Low
beam & 60w on high beam.
Duster, are there any issues with heat or the higher draw with the Silverstars? Is the wiring adequate for the load? I don't know what the alternator puts out on an AN 650. Thanks.
I've been running the halogen bulbs for several years.
No heat problems, even though the replacements are
rated at 55/60w compared to the OEM at 35/35w.
Just did a post on my new LED's. Hundred smackers and 10 minute install time. Works great and brighter than crap.
1 - 13 of 13 Posts
