1 - 4 of 4 Posts
Hi, Anybody had this before?
2014 650
Bike wont start. Turn key on, no display on dash display but engine turns over OK but will not fire up. No light under seat either. Manual suggests 10w fuse gone on Fuse box 4 but checked that and it looks intact. Could this be anything else oher than fuses? I will change that 10w when I can get one anyway but wondered if anybody else has had this problem? Battery is fine.
Cheers.
The first thing I do is check all the fuses (under seat and dash) by pulling/visually inspecting them. Sounds like either a fuse or switch but should be under warranty unless you added electrical farkles.
Check fuse box 1 (under glovebox pop off panel, outermost fusebox), #3 fuse (10a). It controls the dash, seat light and fuel according to my interpretation of the 2013 wiring diagram.
Ed
Thanks Ed, Yep that was the problem. I was checking the 10a fuse under the seat!
Problem sorted.
1 - 4 of 4 Posts
