1 - 4 of 4 Posts
So you guys talked me into getting a GIVI Maxia III case and the admore lighting kit and I am going to try to tackle the wiring part tonight. Does anyone have the wire color match up for the 650 off the top of their heads? I have the wiring diagram for the bike but since I failed electrical engineering class it isn't making much sense to me.
The Admore instructions have a 6 wire harness which is supposed to go like this:
Blue and Red - to tail light wire
Green - to right turn signal
Yellow - to left turn signal
Black - to ground
Purple - to brake light
Wiring diagram from manual for right side:
brake - W/B, B/W, Gr
turn - Lg, B/W
license plate - Gr, B/W
left side:
brake - Gr, B/W, W/B
turn - B, B/W
I know one of you Gurus can make sense of this.
Not sure exactly what you're looking for but the abbreviations are colors:
W/B= white with black stripe
B/W= black with white stripe etc etc,
But I don't trust all color codes in manuals.. A test light is your best bet to verify the color you think you need is actually the right one.
Well I am trying to figure out what wires to hook the Admore lighting harness to to make it work correctly. I guess I am going to try the following but this may change once I get the tupperwear off:
Admore harness to Burgman wires:
Blue and Red - to Green
Green - to LG on right turn harness
Yellow - to B on left turn harness
Black - to B/W
Purple - to W/B
Blue and Red - to Green (NOT GREEN - IT IS GRAY)
Green - to LG on right turn harness (LIGHT GREEN)
Yellow - to B on left turn harness (BLACK)
Black - to B/W ( BLACK with White stripe)
Purple - to W/B (WHITE with Black stripe)
I think I got things install OK but the mounting bracket for the GIVI case is wrong so I have to find the correct one tomorrow. :cwm10:
1 - 4 of 4 Posts
