1 - 7 of 7 Posts
I'm new to scooters so bare with me. I recently put in a new K&N air filter in my 08 400. I read somewhere that some (air/fuel) adjustment needs done to regulate gas consumption. Is this true and if so how do I go about doing this? I'm asking because it seems like my MPG has DRASTICALLY decreased since installing the air filter.
Go on a DIET...............!!!!!!!!!!!!!! :lol: :lol:
· Premium Member
there are no adjustments , the computer does it all, what you probalbly have is a mif maintenance induced failure, whike you rere farkling with it, doing something suzuki didn't get paid for, you may have dropped a tiny bit of cut off filter or plastic or some other kind of detritus down in the feed me air hole and now it's not feeling so well as before , if you fix something and now it's broke, the first place to look is where you fixed it
The mix is controlled by the ECU and monitored by the O2 sensor on the exhaust pipe,
it can be altered by using a computer program your dealer may have it, or by http://www.dynojet.co.uk/index.php/splash
or something like it, a cheaper and much cruder way is to get a adjustable o2 eliminator that is only really a adjustable resistance
that modifies the O2 output and fools the ECU into running the engine richer or weaker, but to be honest I doubt you have a problem
and would fill the tank and do a mileage test to be sure.
· Premium Member
If the K&N filter makes the bike louder, this might be a psychological thing- running it harder because it sounds cool?
The only way to find MPG accurately is to keep a running tally- I made my own spreadsheet- after several fill-ups you will be able to get a good picture.
Plus I fill up each time, to make it easy. After several tanks, which eliminates overfilling sometimes or underfilling sometimes, you can get an accurate MPG.
Personally I would not run K&N. You can clean the stock filter with Simple Green many times.
I ran K&N in my Shadow because the non-cleanable paper filters cost as much as a K&N. And I was living in NW Arizona (the dusty desert) so a reusable, oiled filter made sense (cents too) :)
But others have stated that K&N allows more air to flow = larger pores = more dirt in engine.
1 - 7 of 7 Posts
