Well a rainy day, some time to spare and I added two USB power ports, installed my Fuzeblock power management and wired in the outlet for my heated gear.
Borrowing a great idea I saw here on BUSA I installed my Fuzeblock in the stock tool kit area. This gave easy access to the battery, and it was no hard to run wires up to the dash. I used two of the 6 connections in the block for the heated gear, two for my USB outlets (I know over kill, but I wired one to be constant supply and one to be switched). and took the time to hook up the remaining two and run wires to dead head in the dash for future use. With the heated gear using 15 A, the USBs maxing at 4 A, I still have 11 A for future use. I figure on adding LED Aux Driving lights.
I've wired the top USB to be constant on, I figure a plugged in cell or GPS in an emergency sucking 1 amp isn't going to kill anything too fast (and it's super easy to change if I want - just move the fuse to the other side.)... The bottom one is switched as are all the other connections in my setup.
