I'm not referring to locking the ignition. I'm referring to locking your bike to a a tree or a pole or using a disk lock through the wheel spokes. I put a little sticky loose leaf reinforcement over the doohickey that prevents access to the ignition.Randy said:I am not sure I understand your post, you know the ignition is locked because the key is out, that's the only time it comes out I thought.
It's funny I missed that because I did forget to remove a disk lock on a different bike years ago,I'm not referring to locking the ignition. I'm referring to locking your bike to a a tree or a pole or using a disk lock through the wheel spokes.
The lock I use is not specifically a disc lock, it's a u-shaped Kryptonite lock that is large enough to fit over the tire and between the spokes.philtag6000 said:There's no holes in the brake disc, so how do you use a disc lock? :?:
I use the kill switch (off position)to remind myself about the cable
lock on the front wheel.
