1 - 5 of 5 Posts
Never liked the "tiny" sound of the stock horn.
Replaced with FIAMM 40365 D Low Tone this AM. I am a rider not a "wrench" and It took me 45 minutes. No additional relays etc. Plug and Play like
Stock horn rated at 105dB. Fiamm 130dB
Stock horn draw 3 AMP. Fiamm 4 AMP
OSHA rates a power mower at 107dB, Pneumatic riveter at 4' 125dB
Significantly louder and more annoying, very similar to the Goldwing now
Pop off the lower leg shield, black thing in front of the radiator, two rivits, two screws
Stock horn is on the upper right, facing the rear of the bike
12mm to remove bolt holding horn bracket, pull off female spades
Remove stock horn from stock horn bracket, KEEP STOCK HORN BRACKET
Remove FIAMM horn from FIAM horn bracket
Re-Install FIAMM horn on Stock horn bracket. Male spades at 10 o'clock position, same as stock
The FIAMM male spades are wider set than Stock, so "nip" the two plastic "bridges" between the stock female spades to gain a little room
Connect female spades to male spades
Re-Install stock horn bracket with FIAMM horn attached
Re-Install tupperware
Bill
Discussion Starter #2
Forgot to add
Cost was about $13. Don't remember where, I bought it for another bike, never got around to installing :wink:
"Goggle' Fiamm for sources
Bill
I'll be using Fiamm's #72102 "E" HighTone Freeway Blaster, rated at 132dB.
Obnoxiously loud!!! :shock: :shock: :shock:
I picked up the Freeway blasters, high-E and low-F. The high-E was significantly bigger than the old horn abd the low-F. I popped it on using steps similar to above and had some problems. The horn would hit the back of the fender over speed bumps. It also hit the left fork when turned almost as far as you need to go to activate the ignition lock.
Has anyone else had problems replacing the horn on a 2005 650?
1 - 5 of 5 Posts
