1 - 3 of 3 Posts
Hello all, I am wanting a device that will open the seat catch on my 2014 650 ex without useing the key. if it sticks and does not open when i am away from home i will not be able to get my helmet and gear from under the seat, In the uk you cannot ride without a helmet so i need to open it without the key if the key does not work thanks for any reply. :kermit:
There are lots of posts on this subject. Search for 'seat lock'. I have fixed a fishing line to the lock, and had to use it once when I lost the key for a short while.
Yep....a 30 to 50 pound/test steel fishing leader
18 to 24 inches long works just fine. Just remove
the swivels from one end, & loop that end around
the seat latch release lever, & then 'fish' the other
end down under the plastic fender to someplace
where your finger can find it, & attach a split keyring
as a finger-pull......done...problem solved. ;)
1 - 3 of 3 Posts
