1 - 9 of 9 Posts
Plastic Body Parts Compatibility ?
Forgetting about the color for the moment , are all the body parts compatible through out the years ? Naturally excluding the 2013 model .
TheReaper!
One part that I know is not compatible is the front box. There are I believe 4 different part numbers depending on the specific standard or Executive model you have. I know for sure the standard front box will not fit on the Executive because of the ABS unit.
what about the rear tire?
Tires are all the same but the wheels are different between the standard and the Executive.
What is the difference between my 08 non Exec and an Exec rim?
The Exec rim has the mounting points for the ABS sensor ring. The standard rim does not. You can put a Exec rim on a standard with no problem. If you put a standard rim on an Exec you cannot mount the sensor ring so the ABS will not work.
I will make note of that. Thanks.
1 - 9 of 9 Posts
