1 - 3 of 3 Posts
You are searching for a very unique item. You should create a search on ebay and have the results sent to your inbox every day. I do that for the seats. If the mirror frame cracked, you may be better buying off any available mirror and having it painted. If it is the blinker lens, they come up every so often.
I recently had to replace the mirror and turn signal on my 09 standard 650. I was shocked that the MSRP was approaching $150 for the mirror. However, I went in shock when I found out that the turn signal doesn't come with it and it was nearly $50. If you have the time, keep looking because the left mirror will have a better chance of being available than the right one.
1 - 3 of 3 Posts
