1 - 4 of 4 Posts
Replaced my fuel door, the hinge was okay. Read a few posts here about installing the clip but still having problems. The forum postings stated to just flex the metal clip to get it secured at the bracket and edge of door. The clip is very strong and have not been able to flex/bow with my fingers. What is the trick does one use pliers to flex the spring clip. Thanks in advance. Doorless ;)
I don't know that there is trick. I was able to get mine to go in just using my fingers.
Thanks Buffalo for the encouragement. However, I had to use needle nose pliers to flex the clip, guess my crusty old fingers are not as strong as the used to be. Thanks for your reply. Mike
Glad you were able to get it done.
1 - 4 of 4 Posts
