ted clement said:
The 400 does not have a transmission. Therefore you put 10-40 or 20-50 in the engine and rear gear drive.
Well, no -- it has a transmission ( a mechanically actuated CVT), but it's not a three point lube arrangement like the 650.
Burgman/Skywave 400 Specs:
Engine: 385cc, four-stroke, liquid-cooled, single-cylinder, SOHC, 4-valve
Bore Stroke: 83.0 x 71.2mm
Compression Ratio: 10.2:1
Fuel System: Fuel Injection
Lubrication: Wet Sump
Ignition: Digital/Transistorized
Transmission: V-belt, CVT- automatic
Final Drive: Shaft
Overall Length: 2260mm (89.0 in.)
Overall Width: 760mm (29.9 in.)
Overall Height: 1375mm (54.1 in.)
Seat Height: 695mm (27.4 in.)
Ground Clearance: 125mm (4.9 in.)
Wheelbase: 1590mm (62.6 in.)
Dry Weight: 184kg (405 lbs.)
Suspension Front: Telescopic, oil damped
Suspension Rear: Link-type, adjustable preload
Brakes Front: Single hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 110/90-13
Tires Rear: 130/70-13
Fuel Tank Capacity: 13 liter (3.4 gal.)
Color: Silver, Blue
