1 - 10 of 10 Posts
· Premium Member
I have posted a sub album in:
Linky
to cover this procedure.
WARNNG: THIS IS ON A 2000 MODEL 400 - PROCEED WITH CAUTION IF YOURS IS LATER THAN THIS AND CROSS CHECK WITH YOUR MANUAL.
AS WELL AS BEING TASTY COFFEE CAN ALSO BE VERY HOT.
Norman, my service manual for '03-'04's says the "service limit is 20.85mm (0.82 in), but then goes on to say "if the measurement EXCEEDS the limit, the belt should be replaced". I assume they mean if the measurement is 20.85mm or less, replace the belt?
What was the measurement of your belt?
· Premium Member
Hi Ted
Mine is a service limit of 22mm.
As measured (average across 6 measurements) 23.22mm.
I will put your data for service limit for your year in the How to.
Edit: Sorry Ted I did not answer your other point. Your assumption is correct the belt should be changed if it is at or below the specified width (Service Limit). In my manual there is all sorts of quaint phrasing - I suppose the translation into technical English from technical Japanese is responsible.
The high miler rider in my group of 400's will soon have 12K on his and we will be checking the valves again. Will be interesting to see what his belt measures, as well as the valves since his wasn't adjusted until we did it at 6K. Will let everyone know the results.
Norm.... how often should you change the final drive oil... if required
· Premium Member
Discussion Starter · #6 ·
I don't have the 400 or the manual anymore, so I cannot give specifics.
I would:
a. Follow the periodicity laid out in the owners manual.
b. If I was picky I would also change it during winter lay up (if you have one). :wink:
· Premium Member
Discussion Starter · #8 ·
Jimmy I have fixed the link - but you can also follow the link to my gallery in my signature.
1 - 10 of 10 Posts
