when I turn the key to run the bike is dead, When I turn the key to parkimg light, the turn signal and em flasher power up? I read it could be a ralay? I want to hot wire it. I have a red, a orange then two tan with a pink stripe. I figure the tail is the orange, the red is hot and the two other wires go to the relays to power up the bike. Any ideas, I don't want to do more damage. The bike has over 40k. THANKS
When I look at the wiring diagram in my service manual for the 05 400. your wire colors don't match what it says. The manual shows six wires going to the ignition switch except for the UK. EU and Israel models which have 4 wires. In either case no tan with pink stripe wires are shown.
The UK/EU/Israel model has a red, orange, orange with green stripe and a black with red stripe wires. According to the manual, when you have the key in the park position you should have connection between the read and black with red stripe wires. When it is in the run position you should have connection between the red and orange wires and between the orange with green stripe and black with red stripe wires.
The other models have red, orange, orange with yellow stripe, black with white stripe, orange with green stripe and a black with red stripe wires. When you have the key in the park position you should have connection between the read and black with red stripe wires. When it is in the run position you should have connection between the red and orange wires, between the orange with yellow stripe and black with white stripe wires and between the orange with green stripe and black with red stripe wires.
