1 - 20 of 26 Posts
2013 Suzuki Burgman 650 ABS
My urge to get a new toy has prevailed so before that can happen...
This is a White 2013 Suzuki Burgman 650 ABS with just over 26700 miles. I will be continuing to ride so miles will likely be a little higher. I bought it in 2018 with 3301 miles.
It has the following standard features:
-eCVT (electronic CVT) with automatic drive mode, Power mode (bumps the RPM up about 1500), and 6 speed manual mode (locks ratios to fixed "gears") with shift buttons on left grip.
-ABS front and rear brakes
-Electrically adjusting windscreen
-Electrically retracting mirrors
-50 Liter under seat storage box
-2 small glove boxes in dash along with one large locking glove box
-12 vdc socket in large glove box
-Parking brake lever on side just below nose of seat
-Adjustable front and rear brake levers
This Super Scooter also has the following added features:
-Corbin seat with covered slot for removable driver backrest (backrest not included but can be added)
-Upgraded seat lift strut with 40 lbs lift force
-Eastern Beaver 3CS 3 position auxiliary fuse block
-Stebel air horn
-90 degree CNC Aluminum valve stems
-Suzuki branded aluminum rear top case mounting plate
-Suzuki branded 46 Liter top case (actually the Kappa K49N with Suzuki badging)
-Rear LED running light bar with flashing brake light mounted under the top case mounting plate
-RAM ball mounted on top center of dash hood
-SAE pigtail connector with inline fuse for BatteryTender
-Hella H4P50TB +50 headlight bulbs for 50% more lighting distance (original bulbs still good and included)
-Bungee cord studs added to bottom of pillion grab rails (2 on each rail)
-Official Suzuki service manual is included along with added electrical diagrams for what I have installed
This Burgman is in great condition. I currently have a Shinko SR567 front bias ply tire and the OEM Bridgestone TH01 rear radial tire. This combination has been working really great together. It is the same kind of matchup as used on racing bikes (bias front with radial rear). I find my Burgman rides the curves like it is on a rail. I did drop it once from a standstill and that resulted in a slight scrape on the fairing. The right brake lever was replaced with new. When I bought it there was a crack in the lower leg shield under the right foot board which I completely repaired. I just recently replaced the joint headlight connector with a better sealed weatherproof connector. Overall the condition is excellent. During my ownership I have regularly achieved from 58-62 mpg for all riding speeds during the summer riding season.
Added farkles have detailed documentation posted on the BurgmanUSA.com forum.
The Corbin seat is hands down THE MOST COMFORTABLE seat to ride distance on IMO. I would recommend anyone to consider getting a Corbin seat for any bike they ride. I can sit on this seat all day and still be comfortable when I arrive at the destination as when I left home. It has no rips or tears in it and is in near perfect condition. There was one thread loop that looked like it was about to wear through so I sealed it with E6000 sealer to prevent any possible damage to the seat.
All maintenance has been regularly completed and I have a chart showing dates and mileage for all maintenance performed. Just put on a new Bridgestone TH01 rear tire. New rear wheel bearings were put on at the last tire change. I replaced the battery and the front brake pads in May 2021. Rear brake pads and pad pins were replaced in June 2020. Otherwise all maintenance has simply been oil changes and filter changes.
Pictures show a USB-C phone power cord along the inside top of the dash hood that I will be keeping since it is specific to my cell phone.
$4700 OBO
Clean title in hand.
I am able to pick up at the airport for those who wish to Fly-n-Ride.
Suzuki 2013 Burgman 650 ABS pictures (PM me if you have trouble seeing the photo album)
Here are a few pictures just because:
Tire Wheel Vehicle Automotive lighting Automotive tire
Tire Wheel Fuel tank Plant Vehicle
Tire Wheel Vehicle Automotive tire Automotive lighting
Automotive lighting Automotive tire Hood Motor vehicle Synthetic rubber
Speedometer Motor vehicle Plant Gauge Vehicle
Automotive lighting Light Hood Motor vehicle Bicycles--Equipment and supplies
Discussion Starter · #2 ·
BTW- Clean title in hand.
You might want to add your location.
Reactions: rjs987
Discussion Starter · #4 ·
Location is in my profile avatar when you float your mouse pointer over the avatar. But for those who don't know how to float...
West Des Moines, IA.
Reactions: wspollack and JRoss
Wow ! there’s nothing left to Farkle …. I bet some Gold Winger does the math and snatches that one up.
Discussion Starter · #6 ·
The only thing I didn't add was a cup holder. So farkle away!
Reactions: DarisPakar
Interested, but I'm in NC, so visiting to see it no small task. Please keep me informed if you sell it, but if I can arrange a trip up there before you do, I'll let you know.
Good luck with your sale and new purchase!
Discussion Starter · #9 ·
I am planning on stopping by Wheeler Powersports dealership on Thursday, Sept 23 just to look. If anyone just happens to be around Fort Smith about mid day...
Will be riding my Burgman down there for a camping/riding event just south of Harrison (which is another location where this bike can be seen). 😁
Reactions: Dave_J
She's a beauty. Nicely done. I had Corbins on two of my three Burgman 650's and they make a night and day difference. It's a totally different ride and worth the money. I'm not in the market for my fourth B650 at this time but this would be intriguing if I was.
Discussion Starter · #11 ·
Price reduced... see original post
Discussion Starter · #13 ·
Special forum member pricing now in effect!
Sent from my Pixel 4 using Tapatalk
Discussion Starter · #14 ·
Just returned from an 1179 mile trip from Iowa to AR and back. Bike performed flawlessly. A really great bike with extras.
Discussion Starter · #15 · (Edited)
Just put this Burgman up on eBay for a super low starting bid price. Get it now there or here before the bids start to rack up. Only there for 7 days.
Reactions: Dave_J
GLWS.
I sold my 2000 Valkyrie on eBay in 2007, and it went well.
Reactions: Dave_J and rjs987
Discussion Starter · #17 ·
eBay auction on this ends Monday afternoon. Get it there while the price is lowest... or get it here after that. Make me an offer.
Reactions: Dave_J
Discussion Starter · #18 · (Edited)
eBay listing was extended. Bargain starting bid way under NADA and KBB average retail for STOCK scooter, not including all the farkles included on this one.
Discussion Starter · #19 ·
Pricing in this thread on this scooter is also way under NADA and KBB for the factory stock scooter.
Discussion Starter · #20 ·
If this is tempting at all contact me using a PM! 😃 (float mouse pointer over my avatar and select Message from the box that pops up).
Still available and not yet too late in the year to get this one.
Reactions: Dave_J
1 - 20 of 26 Posts
