1 - 4 of 4 Posts
Just curious (for now until I have to perform the task)...how do you access and then change the front turn signal bulbs? Also, I saw the video on how to access the headlight from below the fairing, but how would you access/replace the smaller bulbs above (hi-beams)?
One of the members here, micbergsma, has a TON of videos on YouTube that cover just about everything you could think of doing to your Burg! Look for his channel, they're very well done. :)
Actually, I did search You Tube and found some GREAT videos...but nothing about the front signals or smaller bulbs (I presume are high beams). Rear lights, yep there are videos, but nothing up front.
The high beam is a different filament
in the same bulb as the low beam.
1 - 4 of 4 Posts
