1 - 11 of 11 Posts
Hi Gang
I started noticing a difference in the performance of my ride, my RPM's have increased between 2-300rpm to maintain a 70mph cruising speed. Another is the bike is coasting with much less engine braking and during a very slow takeoff there is a shutter (Slip-grab-slip-grab-slip-grab) from 1600-1900rpm (Not violent but very noticeable) from 2K rpm she seems to pull good but revs increase a lot quicker and a bit higher than normal. She is a 2012 Executive with a tic under 27,000 miles and my riding habitat is NYC (5 Boroughs) everyday except for Ice and snow.
Looking for opinions on whether or not I should lay the bike up and remove the clutch. Thanks in advance for any and all assistance/advice.
Did you do an oil change recently ?
I changed the oil October last year and she seemed fine then. I use Castrol SAE 10w-40 4T motorcycle oil which has the JASO MA-2 & API SG certifications.
Well it’s not the oil then....
We have had reports of people with similar problems using different oils than what you used.
Seems low milage for the clutch but if your not sure of the bikes history then it's possible. There is a test for checking the clutch, think it's in the workshop book. Anyway the good news is it's dead easy to swap. I picked up a second hand one for my 2006 and had it all changed in a couple of hours. The whole clutch just slides off once you have removed the outer cover. You might need to get a new gasket to be on the safe side.
Found it, Buffalo posted it way back.
There is a test procedure to confirm it:
Start the bike and warm the engine up.
Sit on the bike and apply the front and rear brakes as firmly as you can.
While watching the tach open the throttle fully and note how high the rpm goes. Do not hold the throttle open for more than 3 seconds.
The tach should go to somewhere between 3200 and 3800 rpm and stop, If it goes higher the clutch is slipping.
I've had the bike since new and have used the same oil the entire time but my riding environment here in NYC is rough on equipment and I feel too that the mileage is a bit low but wasn't quite sure if all of the stop and go would actually cut the life in half.
Discussion Starter #8
I didn't see that in my shop manual, I will go warm her up and give a run and get back to you. Thanks
Discussion Starter #9
I found it under section 2-32 for clutch engagement low and max, engages at 2k consistently ( A bit high) and at max throttle with the brakes locked for no more than 3 seconds she only got to 3400rpm.
Thanks for the info I missed the full throttle test outlined in the manual. I'll keep going till she hates it. LOL
1 - 11 of 11 Posts
