I did an installation today of some small driving lights and LED light strips and naturally had to remove much of the tupperware to gain proper access to make my changes.
Originally, it was my wish to install the front driving lights on a wire that was controlled by the ignition switch, so that the lites could be on with either high or low beams when the engine was running.
Having the front end all stripped down, I could not locate such a wire that would perform the job as I wanted. I had to make a choice of either the high or low beam circuits, so I chose them to be on only on the low beam circuit only. I would like them to be able to run on both circuits if possible.
Is anyone familiar with the wiring system enough to suggest anything else? As you may know, it is very tight and most everything is wrapped up pretty well.
