1 - 7 of 7 Posts
Hi folks. Thought I would share my story in hopes it may help somone down the road. After letting my scooter sit for around a month I fired it up. After it idled for about 4 minutes it died and would not restart. The next day it fired up and a few minutes later died. When it was completely cold it would run fine but as I would rev it up as it warmed it would start to cut out then die. Found a thread on here that sounded identical to my problem but it was never resolved or the fix was never posted. I took the plug out and cranked it over. Had good spark and was squirting fuel out. Well now I was confused. Swapped the plug with another scooter that has the same plug. Noticed some moisture on the plug so I blasted air in the boot. Wouldn't start. Ugh. Old plug back in, ran for a few then died. Time for the dealership.
I was expecting the worst. Got the call it was ready to pick up for $118. They tell me they put a new spark plug in it and found moisture in the plug boot. I assumed they fired it up, it ran so they parked it and called it good. I picked it up let it run for about 15 minutes before I left. Nervously left for a road test. I road it for 151 miles yesterday and it ran great. My guess is my little air compressor didn't have enough psi to blast the water completely out. I don't know where the water came from. Since I have owned it I have not ridden in the rain or washed it with a hose. I will update if have any other issues but for now I'm going to call this solved.
So have any of you had a problem with water? Should I be concerned about riding it the rain? Thank you all for the info found on this great forum.
Weird, I've never had any issues with riding in water, and here in Seattle it rains a LOT.
Hi and welcome to the group. :) Here in the UK its always wet !! But thankfully I cannot say I have had the problem with our Y or L2 model 400's and find the spark plug and its cap well protected from road spray, garden hose when washing etc.
As well as blowing out with your compressor air line, a spray with a water dispersant such as WD40 may have helped your situation although I have to say I have never encountered a plug /cap that was wet enough on the Burgman to warrant that............two and three cylinder two strokes in the '70's were different beasts and often shorted with the lightest of rain. :-(
Hope you enjoy the bike now its going and don't have a repeat occurrence ? Take care and look forward to the fine weather.
I've crossed rivers with my 400 in San Antonio! No issues still running after 40000 miles.
1 - 7 of 7 Posts
